I Am currently installing a N2MB WOT in my Z. Everything appears to be working correctly with the exception of the clutch signal. According to N2MB Racing this signal should come from pin 5 on the ECU. I have already rewired twice as well as reviewed the wiring schematic. I can't find any information that shows a clutch signal going to the ECU. I guess last resort would to be tap into the clutch switch but the wire is not long enough and I really don't want to splice the wire unless I absolutely have too.
Can anyone confirm that this is the correct ECU pin?
Thanks!
Clutch pedal signal @ ECU? - SammybTT(TN)15:39:37 08/16/14
